Ncase M1 with AMD 4700X and 3700 Nvidia is planned ~1600 Euro
Bullz
42
Hello, ( i am from austria )
after i abandoned my plan with the Dan SFX i will realize my pc with a ncase.
Goal: Best of price, performance and volume what is possible
What I have searched for is not fixed but as an orientation:
Samsung SSD 970 EVO 1TB, M.2 (MZ-V7E1T0BW) 135 euro
Crucial Ballistix black DIMM Kit 32GB, DDR4-3200, CL16-18-18-36 (BL2K16G32C16U4B) 139,50
Corsair SF Series SF600 80 PLUS Platinum 600W SFX12V (CP-9020182-EU) 117 Euro
CPU should be 65 Watt class
GPU 210 Watt class
I paid a little attention to this guide which already shows a lot.
Kühler there are 3 opinions. AIO or U9S ( compatibility ) or C14S ( performance needs v6 or v6.1 )
I am grateful for every tip and will put some pictures in the forum.
Bullz
42
Now I have my 2 te compilation. I am from Austria :)
My power consumption never exceeds 90 watts with the CPU
5 fans. 2 bottom, 2 side 1 rear.
AMD new gen
nvidia new gen
Mainboard so far no real recommendation for the board read.
Ram surcharge on 3600 Mhz relatively salted. Really necessary for sweet spot ?
Noctua NH-C14S and Corsair SF Series SF600 fixed. No AIO no water cooling
I would like to build my case like on this page even though I will never be able to put it together like this :/
1 Kingston A2000 NVMe PCIe SSD 1TB, M.2 (SA2000M8/1000G)
1 AMD Ryzen 7 4700X
1 Crucial Ballistix black DIMM Kit 32GB, DDR4-3600, CL16-18-38 (BL2K16G36C16U4B)
or
1 Crucial Ballistix black DIMM Kit 32GB, DDR4-3200, CL16-18-18-36 (BL2K16G32C16U4B)
1 EVGA GeForce RTX 3070
1 MSI MPG B550I Gaming Edge WIFI (7C92-002R)
3 Noctua NA-SEC1, 30cm
3 Noctua NA-SYC1, 11.5cm
3 Noctua NF-A12x25 PWM, 120mm
2 Noctua NF-A12x15 PWM, 120mm
1 Noctua NF-A9 PWM, 92mm
1 Noctua NH-C14S
1 Ncase M1 silver, Mini-ITX, V5 (M1V5S20000)
1 Corsair SF Series SF600 80 PLUS Platinum 600W SFX12V (CP-9020182-EU)
Frenzy
48
The main components you mention would still fit in a DAN A4 though, so performance per volume is still with that case.
Having both DAN A4 and Ncase, Ncase defintely leaves more option for cooling obviously, so Goal is also quiet running then?
The imgur reference not working for me at the moment. Whats so special about it? I dont see anything in particular and he indicated to deshroud the gpu etc.
To note 3700x not really 65W more like 90W in practice. Lets see if the 4700x does that better.
I went for 32GB, 3200Mhz RAM in my system but i see the pricing is better now. 140 euro for 3200 and 150 for 3600 then just got 3600 yeah.
toilettendealer
Are you going to use the front USB C port? If not, the B550I Aorus Pro AX might be the better choice when looking at performance. I checked Ali's video and he did some testing (starting at 6:52). And did you consider watercooling your CPU, since it could get hot if AMD improved their CPUs alot.
