Hi guys im new here and happy to be here
My requirements or main goal with the pc: playing WQHD @144 hz and some video editting
I am currently thinking about building the Ncase M1 v5 with the following specs and hope to get your views:
Budget is about 1500€ (germany)
cpu: ryzen 7 3700x (best value for money imo)
gpu: rx 5700 xt gigabyte oc (same)
cpu cooling: Corsair Hydro Series H100i RGB PLATINUM ( I want an aio because of transportation issues and it has some of the best cooling as well hasnt it?)
mainboard: Gigabyte X570 I Aorus Pro WIFI AMD X570 So.AM4 Dual Channel DDR4 Mini-ITX Retail (it has m.2 pcie 4.0 which is nice and is a good mainboard overall i think?)
psu: 600 Watt Corsair SF600 Platinum (450 Watt is too low I think and this one seems pretty good)
Ram: 16GB G.Skill Trident Z Neo DDR4-3600 DIMM CL16 Dual Kit (fastest ddr4 for this without any oc or so which i dont do anyway, got it from linustechtips youtube video on amd ram)
storage: 1000GB Corsair Force Series MP600 M.2 2280 PCIe 4.0 x4 NVMe 1.3 3D-NAND TLC (CSSD-F1000GBMP600) (fastest m.2. NVME ssd currently which is perfect i guess)
case fans at the bottom: 2x Noctua NF-A12x15 PWM 120x120x15mm 450-1850 U/min 23.9 dB(A) (need some smaller because of the thick 2,5 slot gpu and think these one are the best)
https://pcpartpicker.com/list/HVsBPn (couldnt add the case...)
Yeah so I am looking forward to your views on this and one last question:
Do you recommend some custom cables since the case is pretty small and I want the perfect cable management without too much chaos inside?
Sry if I have some english issues I am not native
Thank you very much in advance!
