With the launch of new hardware approaching us I decided to do some bench marking and thermal testing with my current setup. I plan on doing some similar testing with the NR200 when it arrives and Sliger's new Cerberus Mini cases which are expected to be launched in October sometime.
10900K at stock 4.8 Ghz all core
Gigabyte Z490i Aorus Ultra
Adapative Vcore with -140 mV offset, LLC Medium Vcore 1.21 | VR OUT Vcore 1.152 under heavy load
16GB DDR4 3200CL14 @ 3600CL15 with tightened timings
EVGA 2080 Ti XC Ultra 862 mV @ 1905 MHz (settles at 1875 Mhz) EVGA fans set to max out at ~1100 RPM
Samsung 960 EVO 1TB M.2 NVME SSD
CPU cooler is the Noctua U9S with a second 92mm fan set as intake from the rear. Two Noctua A12x15 mounted outside the case to bring fresh air to the GPU. The side mounted Noctua A12x25 is set to exhaust.
CPU Thermals
The U9S and side exhaust fan were set to 100%, the A12x15 fans were running at around 33%. The GPU is normally ran with the undervolt but I left it stock for this test.
Real Bench 2.56 51 Minutes
CPU AVG 76C to 80C
CPU MAX 79C to 85C
CPU PWR AVG 157W
CPU PWR MAX 168W
GPU AVG 74C
GPU MAX 75C
GPU PWR AVG 258W
GPU PWR MAX 264W
Blender Benchmark
CPU MAX 74C to 81C
CPU PWR MAX 183W
GPU Testing
This was done with the previously mentioned undervolt, 862 mV at 1905 MHz which settles in at 1875 MHz. Memory overlock is +1000. Total GPU power consumption is around 230W to 240W at full usage and temperature is generally around 70C with the fan speeds between 1000 and 1100 RPM.
Fire Stike Ultra Graphics - 8754
Fire Strike Extreme Graphics - 17534
TimeSpy Extreme Graphics - 7151
TimeSpy Graphics - 13148
Port Royal - 9266
Superposition 4K Optimized - 12427
CPU Thermals
CPU AVG 76C to 80C
CPU MAX 79C to 85C
CPU PWR AVG 157W
CPU PWR MAX 168W
GPU AVG 74C
GPU MAX 75C
GPU PWR AVG 258W
GPU PWR MAX 264W
Blender Benchmark
CPU MAX 74C to 81C
CPU PWR MAX 183W
GPU Testing
Port Royal - 9266
