Hi all,
Update (9th January 2017) : here is link for Black & White with Red touch
Update (28th January 2017) : Nano² Setup was sold and prepared to her new owner. Here is her last gallery. Now I will focus to build my next setup in a Kimera Industries Cerberus-X
Behind this title of Nano², I just wanted to highlight the combination of the famous "Nano" enthousiast components :
Please also note that this case with normal ATX psu is pretty limited with GPU selection, here is a very good video about :
Here is the BOM of this setup :
So let's dive in details :
As you can notice, internals are just so clean...it's a shocking improvement compared to what I was used before.
You can also note the larger clearance between PSU and GPU.
Dislike many users of Nano S, I decided to keep the top cover, as it won't help cooling and will keep noise level acceptable.
I just LOVE those Gentle Typhoon fans...especially as their motor are really quiet AND their static pressure is huge!..
Static pressure is so needed just behind dust filter :
When I meant DUSTY Gentle Typhoon...I mean that some of these fans are used since 2009 setup..
Closer look at MB area, I like to low width of Noctua U9S...making assembly of the motherboard easier, while cpu cooler is in place. Even with a Noctua U12S, any action on motherboad will required to unmount cpu cooler
In terms of cable management, Fractal Design Define Nano S is just a KING! I managed to arrange all cables, extension, really nicely! Nzxt grid+ v2 is simply sitting on the bottom with no trouble. (ok, ok I'm fan of Noctua extensions..)
I also like the bottom dust filter for potential 120mm extra fan on bottom and PSU. As it's large, you slide it from front of the case, very clever and easy to use..
Let's close the case : Sober, nice and clean!
And now the final comparison between previous and new setup (of course both cats remain..)
Customized Bitfenix Phenom
And here is the final result with Fractal Design Define Nano S :
In terms of cooling management, I'm using the nxzt Grid+ v2 and CAM software. All fans (2xnoctua and 3 gentle typhoons) are linked to this box...I'm not using PWM, because the grid+ v2 allows to cut completely fan when not needed.. Thus I'm have a passive cooling ability...very appreciated at idle/multimedia.
I'm not also using PWM management, as my 2 Noctua fans are subject to not have stable rpm. I mean, for example, on idle, fans are cruising @800rpm...but for 5 seconds they are reaching 1980rpm..for no apparent reasons (no cpu load, nothing). I tried grid+ after noticing this strange behaviour on PWM...and once again as fans are in 800rpm (below 40% on CAM software) they keep turning off and on, alternating low rpm and max rpm. I found the compromise to keep them spinning @1000rpm (40% grid/cam) and they remain really quiet at this speed...so fine!..
Here are the parameters :
In terms of performance :
Globally I'm really pleased of this Fractal Design Define Nano S. With a SFX PSU, this case has no compromise on components choice, while offering great cooling (air & water) and great cable management.
For my point of view, it's the first (in terms of size) case that has no compromise. While you go smaller, you will have more and more compromise in exchange of size shrink..
Last point : I was delighted to be able to re-use my belowed Gentle Typhoon AP15..
- AMD R9 Nano
- FRACTAL DESIGN Define Nano S
- Better looking of my former customized Bitfenix Phenom, while remaining compact
- Really good & quiet cooling potential, in both air and water (if ever I'm coming back to water one day)
- Potentially support all GPU, even 3 slots ones
- Easy and clean cable management and operations
- Optional : to see internals of my computer
- Optional : absorb some coil whining noise with sound dampening foam, or closed case
- Intel Core i7 6700K undervolted @-0.10V (same as in NFC S4 mini)
- Gigabyte Z170n Gaming 5
- SFX PSU, Corsair SF600 with bitfenix black cable extension (24 pins and 8 pins cpu)
- Storage : M.2 pci express, Samsung 950 Pro 512Go
- CPU cooler : Noctua U9S + dual Noctua NF-A9 PWM
- Case fan : 3x dusty Scythe Gentle Typhoon AP15 (1850rpm @12v) (I'm using some of them since 2009..)
- NZXT Grid+ V2 to control ALL fans of setup
- CPU : between 50°C and 60°C on prime 95 (depending on the benchmark choice : #1 : 50°C, #2 : 60°C)
- GPU : on armored warfare @1440p, ultra settings, SMAA
- Stock : 45-47% fans speed, 76-78°C, coil whine mostly absorbed by case
- OC : Power limit +50%, Core : 1080Mhz, 60-65% fan speed, 80-82°C, more coil whine (due to power limit increase) can be heared
- M.2 SSD : From 50°C-59°C in normal/gaming usage, up to 76°C (on benchmark), active ventilation is working well finally as SSD is cooled very quickly while unused. No apparent throttle while benchmarking it.
- Here is the Crystaldisk mark
- 1st test
- 2nd test
- Temperature :
- Compared to same drive in S4 mini (finally I suspect the drive trottle a little bit in S4 mini), there are improvements :
- Noise :
- Idle/multimedia : almost silent (case fans stopped), R9 Nano and cpu cooler fans are spinning very low, generating almost no noise, thanks to closed design of the case
- Gaming : Fairly quiet. GPU is still the most audible component. In my future upgrade, choice of the quiestest gpu will be the main prority.
