Hey guys, I've spent some time looking around for a sff case that i'd think would fit me personally. Sad to say alot of them are either crazy expensive,out of stock for what feels like an eternity or dont have the compatibility that i want so i decided to take my solid works certification and make use of it. After a few days,i have the first attempt at my own personal case.I also plan on modding it so its simplicity helps me alot. Its based on the LZ7
https://pcpartpicker.com/list/RqZxNq Here is a list of parts that i want in the case.
My two biggest things are storage space (i want cheap storage along with an ssd since i video/picture edit) and an sfx psu (i dont trust myself with those werid flex ones). I dont plan on getting a 3 slot card so its not a major problem,and there are so many great low profile cpu coolers,i wasnt too worried there either. The current clearance on it is roughly 65mm,but it also somehow has space for a full hardrive cage (3.5inch x4) and a 240mm radiator at 14.625 liters (roughly). This is only the first rendition of it since i plan on actually making it in a few months,i want as much advice on what i can improve on.
https://www.ebay.com/itm/Dual-USB-P...wer-Supply-ON-OFF-Button-Switch-/223272521506 (this is the power button i plan on attaching to it.)
Thank You
Thank You
