Greetings wonderful people here on SFF,
My name is Chris and I've been developing a laptop concept (admittedly slowly).
The main idea is for a truly portable laptop with desktop parts, that doesn't break the bank and can be transported by plane (as carry-on luggage) just like you would a normal laptop.
General Specs
1. It should also have a large screen and as the maximum size permitted as carry-on, legaly, is around 23-24 inches in a 16:9 type (not ultrawide). LINK
2. It should have external power brick(s) as a regular internal power supply sets off alarms at an airport. I have experienced this with my Silverstone SFF 450W.
3. Desktop components. ITX motherboard and any GPU. At the moment my favorite motherboard is THIS on account of it being powered externally
4. Mechanical Keyboard!
5. Weight under 10kg, Volume under 10L.
Pricing (assumptions)
I can see this laptop being priced similarly to what it might cost you to get the same components in a desktop. We are being told that a laptop with a GTX1060 will cost 1300 €$£. I'd like to imagine a 1000 €$£ best value for money where there's an Ryzen5, RX580 and an IPS screen.
Users
I expect users to be students traveling to and from University/College, workers like myself who have had to travel and need a serious PC that they can upgrade and repair easily and cheaply.
Problems!
LVDS: The connection between an itx LVDS (like on thin-ITX) and the screen panel will be a problem as I don't think the LVDS operates when a dicreet card is connected. In that case it gets more complex and the laptop might have to include the PCB for the screen, which is then powered externally or via USB-C?, and connected to the Graphics card instead of the LVDS.
Thin or Thick?: In the above renders I was considering a thin-ITX, and the GPU having a displaced/parallel heatsink to bring the thickness down which would look great. Now I'm considering the thicker option which could accommodate a ITX with low profile cooler and a normal double slot GPU which would make upgrading easier for users.
So....
I'm here on these forums looking for people who are interested in building this little beast. I'm looking to engineer the chassis and then 3D print a prototype.
Thanks for reading and here's an image that sums up this project and how I feel this product segment doesn't exist. A product between those two and their respective PC's.
General Specs
Users
Problems!
So....
