Hi, apologies for the long post. Feedback is greatly appreciated though!
I've been spending a couple of days to put together a new small form factor build and would love some input as it's been a while since I built my last case.
Main purpose: Something relatively portable as I move it around the house about twice a week. It should last me through Cyberpunk 2077 @1440p and some VR gaming for the next couple of years. My plan is to eventually swap out the GPU for one of the next gen Nvidia cards later this year or early next year.
Reasoning
Thoughts or suggestions are greatly appreciated. Is this a reasonable build?
Component | Name |
CPU - ~€350 | AMD Ryzen 7 3700X 3,6GHz Socket AM4 Box |
Motherboard ~€175 | Asus ROG Strix B450-I Gaming |
GPU ~€580 | Asus GeForce RTX 2070 Super Dual EVO HDMI 3P 8GB |
RAM ~€95 | Kingston HyperX Fury Black DDR4 3200MHz 16GB |
SSD ~€110 | Samsung 970 EVO Series MZ-V7E500BW 500GB |
Case ~€125 | Lian Li TU150 |
Case Fan ~€45 (for both) | 2x Noctua NF-S12A PMW 120mm |
Power Supply ~€120 | Corsair SF600 600W |
CPU Cooler ~€105 | Noctua NH-U12A |
Reasoning
- CPU: I've been debating 9700k and Ryzen for a while. I dont have a strong opinion but Ryzen is cheaper and multi-tasking seems better. The performance in gaming seems marginal once you put it in 1440p. Also it draws less power which should be good for a smaller form factor and heat management.
- Motherboard: Surprisingly hard, but went with the ASUS as it has support for the 3200mhz RAM and two M2 slots. I was considering both the ASROCK and the Gigabyte B450 boards. I only plan to do minor OC, as I only have basic knowledge about it.
- GPU: Pretty simple, seems like great value, good resell potential when I eventually swap up to the 3000-series.
- RAM: Wanted to go with 3200mhz. My understanding is that CAS Latency won't really matter too much (could be wrong), so I went with affordable but good ram. Preferred 1x16GB in case I even want to upgrade.
- SSD: Was first thinking a 1TB M2 drive, but they are rather expensive so went with the 500GB, which should suffice as a system-disk with some games. From what I can see the Motherboard does not support PCIe 4.0 M2 (could be wrong), so I am going with the 3.0. Also seems the best price-to-performance for my purposes.
- Case: Want something portable, so the handle is nice. Seems to have good airflow. A bit on the bigger side for what I want. Was considering something extreme like the Velcase Velka 3, but it seems sold out and hard to get in Europe.
- Case fans: Planning to put 2 fans at the bottom of the case. Would like to get a dust filter though, but I'm having a hard time finding one. Maybe I am using the wrong search words.
- Power Supply: The case requires an SFX or SFX-L sized PSU, and the build is decently hungry, so I am thinking a 600W Maybe I could get away with a 550w, but the price difference does not justify the risk.
- CPU Cooler: I saw a youtube review with this cooler, and it seems good although a bit pricy. I was considering watercooling but I don't think it will be worth it for my purposes.
