Minimised Acrylic Top for 4090FE/ Corsair HydroX Water Block
GPU Minimised Acrylic Top for 4090FE/ Corsair HydroX Water Block 1
petricor
346
1,845
petricor submitted a new resource:
Minimised Acrylic Top for 4090FE/ Corsair HydroX Water Block - Saves 3.5mm in thickness for the smallest possible 4090
A redesigned acrylic top for the Corsair HydroX 4090FE as featured and tested in this build here.
3.5mm thinner than Corsair's original part, with G1/8 screw terminals directly integrated into the cover, making a separate port module obsolete.
For machining in Acrylic, Copper with Nickel Plating or Acetal.
