GPU Measurements of EVGA 1080/1070 FTW
ZA Design
34
Hi!
Can anyone with a 1080/1070 FTW from EVGA measure the length of the card, from the beginning of the pcb/cooler to the longest part of the cooler (which is slightly longer than the card if the images are correct)? The website says that it is 266.7mm, but I think they are using the board length alone, not the cooler to measure it's size.
Thanks a lot!
-ZA Design
