Hello all, I just made an account just to ask this q here. So you may know of the STX 160 build that that guy made that has a whole gaming rig in the size of a PSU? I want to make something similar in size to that using an STX motherboard. STX needs an adapter from ultra m.2 to PCI in order to use a GPU. My problem is the powered m.2 to PCIe x4 adapter recommended by the dude that made the STX 160 is 125USD, which is absurd. I scoured the internet for a cheaper deal, but not one site besides Bplus' own site had them in stock. So I found a similar powered m.2 to x4 adapter on eBay for about 15USD, but it doesn't support an x16 extension to be plugged directly into it like the expensive one does. So I am forced to use a PCIe x4 to x16 adapter/extension. The only x4 to x16 adapter I can find is also a powered riser for about 20USD. Therefore I would have 2 powered adapters. So my question is this: would this configuration even work? If both of the risers are powered at the same time, would it send DOUBLE the power or just explode? Planning to use a GTX 1050ti, so no PCI power will be provided from that either.
Links to my planned parts:
(already have a g4560, cooler)
wifi card: https://www.amazon.com/dp/B00MV3N7UO/?tag=theminutiae-20
antennas (or antennae?): https://www.amazon.com/dp/B00MJU6X5U/?tag=theminutiae-20
motherboard: https://www.newegg.com/Product/Prod...&cm_re=stx_motherboard-_-13-157-723-_-Product
hdplex 160w (160w ac-dc combo): http://www.hd-plex.com/HDPLEX-160W-DC-ATX-Power-Supply-16V-24V-Wide-Range-Voltage-Input.html
m.2 to PCIe x4 powered adapter: http://www.ebay.com/itm/like/192015871521?lpid=82&chn=ps&ul_noapp=true
PCIe x4 to PCIe x16 powered adapter: https://www.moddiy.com/products/PCI%2dExpress-PCI%2dE-4X-to-16X-Riser-Card-Flexible-Ribbon-Extender-Cable-w{47}Molex-%2b-Solid-Capacitor-(30cm).html?gclid=CjwKEAjw8ZzHBRCUwrrV59XinXUSJADSTE5kSCjZwOvqARKaY2VYYWtORbduh7IS5EuKiPdK8xKyVxoCjczw_wcB
GPU, Ram, and SSD: https://pcpartpicker.com/list/RdzKRG
Also a link to the build that inspired me, the STX 160: https://smallformfactor.net/forum/threads/stx160-0-the-most-powerful-atx-unit-in-the-world.934/
Also I just realized the hdplex 160w doesn't have any molex cables, so could I just use some sata to molex adapters? Thanks
