Hi guys,
How do you think an M.2 NVMe PCIe 4.0 drive, like the Western Digital Black SN850 1TB, will behave if installed into a PCIE 3.0 slot?
Will it max out the PCIe 3.0 available speed while staying cold as running at half its speed only?
I am looking for the best 1TB option that will not add too much heat into a case with low airflow.
It will be put into the PCIe 3.0 16x slot thanks to an adapter.
Actually hesitating between the Adata SX8200 Pro ($120), the Samsung 970 Evo ($130), the WD SN750 ($125) or the SN850 ($140).
