Advice Looking to build a powerful pc that can fit in a backpack
1YC45
I was looking for a case that can fit in a backpack and found the sentry 2.0, but sadly they discontinued the case and you can't get it anymore. Any case recommendations?
-Fits in a backpack with room for a mouse and keyboard
-Full-size GPU
-SFX PSU (I don't want an external PSU if possible)
-ITX MOBO
1YC45
Take a look at the Velka 7, easily fits in a backpack.
I took a look at it a while ago and thought that it wouldn't fit in a backpack. I went and looked up a picture of it with a backpack and you're right it does easily fit in a backpack.
HWI
75
58
Yeah, it definitely will. I have a Velka 5, and while it is a little smaller, the backpack I use (28L or 29L pack) to carry it while flying has loads of extra space and would easily fit a Velka 7 with room to spare.
Reactions: 1YC45 and rfarmer
1YC45
Awesome I think I will go with the Velka 7. Thanks for the help!
