Hey everyone, I'm new to the forums but long-time lurker excited to involved in the SFF PC community.
I started my first build in the NCase M1, have done a couple more builds...surprise surprise, I'm back to the NCase M1, attempting my first custom loop.
Here's a link to my FIRST NCase Build: https://imgur.com/a/dVaX0Na
My primary goal is to recreate OptimumTech's NCase M1 Double Radiator build. The only major differences are that I'll be using a 3600/1080ti.
My current part list is as follows:
I'm looking for help, and understand that everyone's time is valuable, so I'm happy to compensate anyone for their time/advice if needed.
I'm looking for the following:
Upon receiving my help, I will plan to do the following:
- Advice on what exact fittings to use inside of my build (how many/what type) - taking into account clearance issues. I will use the exact same radiators, fans, case, etc. as in his videos - I just can't tell what fittings are what visually since it's my first custom loop.
- Advice on what pump to get - I'm planning on: https://www.ekwb.com/shop/ek-ddc-3-2-pwm-12v-pwm-pump
- However, a couple of questions: do I need a heatsink?
- Are there any other variants of this pump I can use?
- Ideally, if you could help me tell me what to buy, places to buy from, etc. that'd be super helpful
- I'm happy to compensate you for your time or donate to charity of your choice
- Document the entire build process visually for other newcomers like myself
- Create a specific part list, down the exact fittings, tubing, liquids used
- Post links to different places to buy everything
- Take final pictures to help any new beginners as well
