Cooling Looking for a thin radiator... really thin.
FoxTrotl_Alpha
38
Has anyone bought these? Planning to squeeze some watercooling into my Raijintek Ophion. I'm open to suggestions :D
Gilles3000
240
244
From what I've seen in the past, that style of radiator hasn't been great. But its most likely is the thinnest one you'll find.
But if you can fit a few extra mm, I'd get the XSPC TX240 instead.
FoxTrotl_Alpha
38
Well, while looking for information on the mighty internet, I've found this: Looks like you really can fit a XSPC TX240 with Silverstone FN123 fans, which are 15mm thick(thin). And the PCIe riser still fits through.
So that makes it about 35mm clearance (15+20.4).
So yay for me :D I can use a proper rad.
Goatee
739
1,513
I have two of those HJ radiators in my T1.
one bottom mounted with 25mm thick noctua fans, one side mounted with 15mm fans.
They give a ~14c water delta and mid fifty’s component temperatures on a 2080ti and 9900K. Fans at max 1500 / 1850 rpm which is audible but pleasant.
FoxTrotl_Alpha
38
Oh, nice. I'm only planning to cool my cpu with it, should be enough. Tho, it looks like its not easy to get them :D
Goatee
739
1,513
They used to only be available from Taobao. Now they are on aliexpress its alot easier than it used to be.
TX240's are like hens teeth.
FoxTrotl_Alpha
38
Oh i meant the TX's are not easy to get. The HJ's i might consider. If two of them can do mid 50's on a 9900k + 2080ti, i think one could cool a 2700x or a 10700 non K.
edit: to be clear, i dont overclock.
Reactions: Goatee
Goatee
739
1,513
Yes, I know. But it has flat tubes instead of round + its a little thicker.
Your opinion? Still go copper?
Copper and Aluminium aren't a good mix. Galvanic corrosion is the risk.
Copper or brass all the way through your loop, no aluminium.
FoxTrotl_Alpha
38
I am aware of that.
I can just buy a alu cpu block.
Question is what would be better:
A copper rad with round tubes,
or a alu rad with flat tubes and a bit thicker.
Pumps are not a concern as most of then have acetal housings/tops.
Goatee
739
1,513
I am aware of that.
Typically (although no always) the decent manufacturers make stuff out of copper, with aluminium the cheaper end.
my advice is go copper (even round vs oval tubes).
Reactions: FoxTrotl_Alpha
