Log Lenovo ThinkStation P360 (P3) Tiny - Intel i9-13900TE & PNY RTX A2000 (12GB) 1L Chasis
1,004
I was about to remark on how low the graphics performance was, until I realised it was Time Spy EXTREME
::EDIT:: Satisfy my curiosity here... do you need to use the GPU direct outputs, or can you connect it via the onboard DP/HDMI ports?
SingleMinded
I was having some issues on first boot, not 💯 sure what was going on, but leaving it for a while it righted itself.
I had to use the onboard DP for first boot, but now can use onboard HDMI, DP or any of the 4x MiniDPs on the GPU
REVOCCASES
REVOCCASES
2,166
3,504
www.revoccases.com
dGPU can also be used with the onboard DP/HDMI ports - on the newer Gen platforms even with little performance penalty
I've seen a couple of Tiny builds with Tesla T4 GPUs that have no display connectors, so the onboard DP/HDMI ports come in handy
Reactions: SFFMunkee
GJA
Sticking to my promise of a post when talking with @REVOCCASES
HERE IS THE FINAL BUILD!
Specs:
Motherboard: Lenovo ThinkStation P3 Tiny (In P360 Case)
CPU: Intel i9-13900TE
GPU: PNY RTX A200 12GB
RAM: 32GB 4800 MHz DDR5
Network: Intel AX211
PSU: 230W Lenovo External PSU
Are you limiting the power via MSI? If I don't do that the power demand as the card ramps up trips the PCI bus.
