LAZER3D has opened up pre-orders for the latest SFF PC design: The LZX-15 (M-ATX).
As you have likely guessed by the name, this 15 liter case has support for mATX motherboards as well as more SFF friendly ITX boards. The case also supports up to 320mm, 4-slot GPUs in certain configurations. If an ITX board is used, it’s possible for a dual 240mm radiator setup. These are just a fraction of the possibilities as the LZX-15 is highly configurable, including as a server with 6 x 3.5″ drives.
Continue reading...
Reactions: K888D and Phuncz
