Log Kubic, my self-designed, 3D printed custom build
WhoIsLudwig
Hi everyone !
I wanted to make a more formal introduction to Kubic, a fully 3D printed, self designed case for SFF builds, with power and efficiency in mind. As its name suggests, Kubic is cube-shaped, and takes cues from classic computers such as the Next computer or the Apple Cube, or the Nintendo Gamecube (for the handle).
It is designed around ITX motherboards and accepts a PCIe GPU card up to 215 mm long without using any expander or riser. Currently, I use an SFX power supply, but I'm planning to switch to some Flex ATX soon, in order to get a few centimeters back for better internal airflow (and maybe a bigger cooler, even though my current Noctua NH-L12S already works great, much better than the stock AMD).
Cooling is based on a top "blower style" 140mm fan. Cool air comes from the left side and the bottom (hence the feet) and flows through the whole case, taking the heat on the way. The top handle serves as a way to prevent, or at least mitigate, the risk of an outtake obstruction. it is also quite handy, especially for a SFF that you're supposed to be able to take along with you easily.
I realize it's quite bigger than many of the SFF builds than you can see around, but it's already packed inside and it still fits quite nicely on a desk or near a television as a gaming system or a media center.
I released it a few months ago on Printables for anyone to grab. I'm using mine for several months now and it never failed me, even though it is fully printed in PLA, which means lower thermal resistance. With the appropriate cooling and airflow, it seems durable enough. I also included several "configurations" for the front panel (with or without audio jack, with or without front USB, ...) and the GPU thickness (2 slots, 2.5 slots and 3 slots).
It requires limited beginner level soldering for the front buttons and the optional audio jack. You'll also need head set brass inserts for durability. So not much, but it's still something to keep in mind. the right panel can hold up to 4 SATA 2.5" drives that will fit behind the motherboard. I'm thinking about a special panel for a single 3.5" drive, but I didn't take the time for that for now. I'm also planning to make a special front panel that can hold a 120mm intake fan for extra cooling
Finally, Kubic is designed to fit on a 180 x 180 mm print bed, so any printer larger or equal than a Bambu A1 mini or a Prusa Mini will work perfectly.
The files are available on Printables and Thingiverse(not yet on Maker World, but i shall soon upload them), complete with detailed printing and mounting instructions. I also added a "blank" panel to let you easily create your own designs if you wish.
Feel free to ask if you have any question, and of course, any feedback is welcome. I hope you'll enjoy the design !
WhoIsLudwig
looks like the pictures I posted don't load, unfortunately. I don't have time to see how to edit the post so for now, Here are some that should work
Reactions: dealda
