Hi Guys,
This is a makeover of a very cheapo mini itx case that is available in the UK/EU.
The manufacturer Kolink has a limited website but the case is very interesting.
The non plus version is apparently 20cm tall, 19cm without the shoes so this case should be identical since the frame is.
I think it is slightly wider than a SG13B because it has room for a pseudo 3 slot card.
length wise about the same but it does not place the PSU above the mobo which is brilliant, since you cannot safely bring an AIO cooled PC in your carry on.
Check out this review.
And the amazon review with pics.
(allegedly it does fit into a ryanair cabin bag)
There are a couple of less-than-ideal reviews of the non plus case on youtube.......(as in they don't test it out with parts)
I was thinking of using this as a step up case until a nicer case shows up (Louqe Ghost S1), or should I just go for the NCase M1? Anyway I am waiting for Asrock to release their AM4 boards.
