Terribly unexciting build, but AFAICT there's no other K39 builds here so thought people might find it interesting. The last image contains the tower I've been using the last 3 or 4 years.
Still waiting on screws for the SSD and a shorter SATA cable before fully buttoning it up, plus considering making some changes.
Case: K39 from taobao
PSU: 400W delta flex, modded to be modular
MOBO: MSI b450i ITX
CPU: Ryzen 1600
GPU: MSI 1070 Aero
RAM: G.Skill Ripjaw 2x8gb 3200mHz
Storage: Samsung 960 evo 500gb m2 nvme & Samsung 860 evo 1tb
Pros:
- Tiny
- Looks awesome
Cons:
- Painful to build in, needs a couple extra mm here or there
- PSU is bloody loud
- GPU now runs a couple degrees warmer than open air, enough for the fan to turn on every so often
- m2 ssd and pch both run hot, but they did even when it was open air
- heatsink for m2 - because its behind the mobo, there'll be zero airflow so not sure it will do much
- Liquid metal - will need to confirm both heatsinks are nickel plated copper
- Backplate for GPU - will likely suffer the same issue as the m2 heatsink
- Drill holes in the front - would likely improve airflow considerably
Would also love to swap a noctua 92x14 fan on the GPU so they match, not sure whether that would help or hurt heat dissipation
