Enclosure Jonsbo C6
hrh_ginsterbusch
707
278
wp-devil.com
You do something interesting with the CPU cooler if you use an SFX or Flex PSU.
Yeah, like add a 240 mm rad. Probably NOT a Liquid Freezer II, but anything else might just work, at least in the height :)
Has a bit of a feel like: Crossover between Meshlicious, a downsized V4 and the Sugo 16.
But with 2x 140 mm option, one might even be able to pull off a custom loop with 2x 140 rads, and feel very comfy.
cu, w0lf.
Analogue Blacksheep
849
705
Looks like the case is beginning to show up in the wild now. Seen it on Aliexpress as well.
Reactions: hrh_ginsterbusch
KuzuBocchi
Honestly wonder if it can fit a reference, 10.5" GPU just for funsies. The case is juuuust as long as one (266mm), and I'm very curious if someone has managed this feat.
