look into slim 92mm fans and see if there are LED versions
otherwise look into regular 92mm LED fans and screws
otherwise look into 120mm LED fans and screws and mounting adapter plates
Make sure you stick to a 92mm fan.
The bigger bearing on a larger fan leaves a hole in the middle of your CPU that isn’t getting much/any air flow.
But yes, you can change it!
