Pick what you like aesthetically or what suits the components you intend to use, pretty broad range of options you have there. I think any of those cases will be a good base for a fun, rewarding build if this is your first foray into ITX. The SM550 will likely pose the most challenge/cost to cool if you're going high end CPU, potentially the XPROTO too depending on how compact you want it to be.
