GPU How tall is 3080/3090 FE PCB?
biopunk
248
359
I'm planning a water-cooled 3080 FE build in FormD T1 using this block from Bykski which seems to be one of the thinnest. It has a cutout for the 12-pin micro-fit connector so the height of that connector will determine the overall clearance required for the card.
Could someone who installed or will be installing a block on 3080/3090 FE measure the distance from the back of PCB to the top of 12-pin connector, please?
D
Deleted member 18401
Guest
Did some pixel counting (based on pcie connector size) for a project some time ago.
3080 FE: ~190 x108mm
3090 FE: ~203 x 134mm
3080/3090 Ref: ~212 x 113mm
Regards :D
D
Guest
Regards :D
Oh misread the question sorry D:
