NCASE M1 V5
EVGA H370 Stinger, 8700(non-k)
Noctua D9L w/two fans at ~1900rpm (Set as intake from rear)
Ambient 18c (cold ass basement)
CPU-Z Stress Tester (default? didn't notice any settings):
94c Side/Top Panels ON
85c Side/Top Panels REMOVED
OCCT (CPUCCT default settings):
90c Side/Top Panels ON
80c Side/Top Panels REMOVED (reading fluctuates +/- 4c)
First: Is this normal? If not, why might I be seeing higher temps than reviews?
Second: When the cpu is place under load, fan speed and temperature increases almost immediately to 70 - 80c. This makes me wonder if the die is poorly transferring thermal energy to the heat sink. It likewise drops to sub 50c within three seconds of ending either stress test. Is this temperature change normal for an i7 8700 or indicative of a sub-par thermal transfer between the die and temp-spreader or temp-spreader and heatsink? It's particularly annoying because anytime the cpu is under a significant load for even just a few seconds, fans go to max.
Plans: I have a blower 1080 ti, a strix 1080 ti deshrouded with 120mm fans underneath, and a 1080 ti with a g12 adapter installed. The blower model is obnoxious, the strix setup is decent and I haven't tested the G12 card with aio.
Lastly: Before I buy a different cpu and/or mobo or cooler, is there anything else I should try? I do have a 240mm evga AIO that I can test on the CPU in an open-case config. I suppose I can test that to see if the rapid temp changes are consistent, but I'd like to see what ideas there are here first.
screenshot of HWiNFO
Noctua NH-D9L and NH-U9S CPU cooler review
We test and review two new coolers from Noctua, the NH-D9L and NH-U9S CPU coolers. These small puppies can be used with any motherboard but focus on Micro ATX and Mini ITX. They are small, deadly sil... Core i7 4790K OC at 4600 MHz 1.3 Volts
www.guru3d.com
Noctua Intel LGA2011 Heatsink Temperature Comparisons - NH-D9L FrostyTech Review
Noctua Intel LGA2011 Heatsink Temperature Comparisons - FrostyTech.com
www.frostytech.com
