im trying to get optimal airflow in my system and make it as quiet as i can and im having trouble doing so. so my system is as stated below
evga z170 stinger mobo
Zotac GTX 1080 mini stock
Intel i7 6700k stock
16GB ram
Cryorig c7 (will be getting C1 its on the way)
3 Noctua NF F12 2 at bottom of GPU bringing air in (one not being used not enough fan headers ordered a spitter) and one on the side of the case to the right of the CPU intaking air as well.
The temps im getting on my cpu is 68c max while playing games at 1440p and my GPU is getting to 79c i know its in the safe range for temps but i want to try and lower it if i could does any one have any suggestions? i know the new cooler for my cpu will bring temps for my cpu down but should i set the fans below my gpu as exhaust?
its also very loud no matter the fan curve i set i fixed the loud cpu but this gpu sounds like it about to lift up off of my desk lol anything helps thanks
16GB ram
