Hello all. It's been a while since I've been active on these boards. Came back because you are all so awesome! I truly hope to hear your thoughts and advice.
The purpose of this HTPC will be primarily for Dolphin/PCSX2 emulation. Right now, I use a G3258/GTX 650 Ti which runs PCSX2 perfectly. The reason for switching to Skylake is all for power efficiency. The idea is to use the least amount of power and a smaller PSU and case.
Here's what I've chosen so far:
CPU: Pentium G4400 3.3Ghz*
Memory: 4GB DDR4 2133Mhz (1.2V)
Motherboard: Gigabyte GA-H110N
Storage: Samsung 850 Evo M.2 SSD (120GB)
GPU: Nvidia GT 740 1GB GDDR5
Monitor: Asus VE205N widescreen 900p (already own)
*BTW, if emulation weren't so processor intensive I would choose the 35W G4400T.
The main question is about the PSU and case. I have several options but unsure which to choose. The first option is for a "thin client ITX" chassis with dual PCI expansion and PicoPSU, eg the Morex 2766. A second option is the Geeek A10 acrylic case and FlexATX PSU. A third option is the Apex MI-008 and single slot GT 740.
Right now I'm heavily favoring second the Geeek A10. One, it is inexpensive which is important. Two, it's PSU is entirely internal and goes to higher wattages than the PicoPSU. Three, no modification is required for the installation.
I like the size and look of the Morex 2766 much more than the A10, but I dislike the age and wattage limits of PicoPSUs (5 years old at this point with no innovations), the external brick, and the price ($74 USD for 150W PicoPSU and 180W brick).
Please share your thoughts/suggestions.
