These are my parts. I have 2 constraints:
1. I have an HDPLEX 400w + HDPLEX 400W ac-dc unit. If I was in the US it probably wouldn't be so bad selling them and getting an SFX PSU but I live in Japan so I'd rather just use them instead of buying a new PSU.
2. It's a hackintosh so I can only use AMD GPU's. If I want an ITX GPU without having to spend a lot I'll have to get an R9 Nano which is problematic on the previous PSU's. I'd be completely fine with a RX 560 (I don't game anymore) except I need at least 2 DP and 1 HDMI to power 3 4k monitors.
The resulting issue is that all the cases which use those HDPLEX PSU's tend to be really small while I'll likely need to fit a normal-sized RX 570/580. I've been doing a lot of searching, going through this sheet over and over but the issue I'm left with in the end is that I'd be forced to buy an R9 nano to use any of the DC-ATX cases as far as I can tell. The one thing I have going for me is that since I live in Japan it's much easier getting Taobao cases (and actually probably cheaper than getting normal SFF western cases). I also have a Chinese friend who could help me order. I'm still stuck though deciding on which case to get. Any advice?
