GPU Gigabyte GTX 1070 Height Question
KMPKT
3,382
5,936
Since this is the tallest card in all the land and I know at least a few of you have it, could anyone please tell me the total height from top of PEG connector to bottom of PCIe socket (or in my case PCIe socket on a riser cable). I am assuming it's about 135mm, but would just like some confirmation since I am often wrong about these things.
cmyk78
384
432
From the top of the power connector to the bottom of the pcie slot (where it meets the motherboard) is 124mm, though the power connector is recessed.
Runamok81
Runner of Moks
Jul 27, 2015
446
622
troywitthoeft.com
I'm getting 122mm?
Give or take an RCH.
KMPKT
3,382
5,936
Okay. So with a PEG in and wires sticking out the top, 135 is a very fair bounding box for this card (ie. you could install the card comfortably with 140mm of space?).
ASCii
(ツ)
Jan 7, 2017
73
55
I had an issue with the height of this card so I found someone to create custom 8-pin low profile cable for me, now he is offering the cable to be purchased as well as other variants.
http://www.ebay.com/itm/IN-WIN-901-Mini-ITX-OC-8-Pin-PCI-E-PSU-Diverter-/332062560513
Here's a photo of the 1070 in my IN-WIN 901, essentially it's just a custom length 8-pin with the bottom of the connector notched to allow cable to bend.
Reactions: Phuncz and jeshikat
