Ghost S1 build / watercooling
AndersaAchilles
hey bros, just build my first ghost s1 fully watercooled, the temps are fine but the flot rate is not right i seems like there is noget high flow rate, it's a eisberg lt solo pump and One gpu heatkiller block, and a 240 eisberg radiator, the pump is Running at full speed i can hear it, i start from OUT to gpu, gpu 2 radiator and then back 2 cpu, i hafe a picture but i dont Know to posted it :) thx hope someone can help
Curiosity
Apr 30, 2016
724
838
Try uploading it to imgur.com?
