Tl;dr: I'm not an electrical engineer, and I'm planning on doing stuff I probably shouldn't. Can you help?
So I'm working on a project that's growing increasingly complex, "fun", and risky at the same time, modding an old Optiplex 990 into a light gaming PC. After discovering that the PCIe slot is limited to 35W and thus can't run anything beyond a 1030 without auxiliary power, I decided to go balls-to-the-wall, got a (really cheap!) used RX 570 ITX, and I'm now working on two issues: how to fit it in the case, and how to power it.
The PC has a (quite shitty, as far as I can tell) proprietary 240W PSU, with a maximum 12V power output of 17A (204W) on its single 12V rail. According to Dell's manual there are two PSU options for this PC: one 80+ rated, and one with a "mean efficiency" of a downright terrible 65%. I'm pretty sure I have the latter, and can't find the former for sale anywhere reasonable, so for now I'm stuck with this (I have options for a PSU upgrade down the line, but that's not in the cards for now - this is a near-zero budget build).
Paired with an i5-2400, 4 sticks of RAM, an SSD and three case fans, some underclocking of the GPU is definitely in order if I'm to avoid blowing the PSU up (or at least tripping OCP (if the PSU has it)). That should be doable, though, as I'm not looking to squeeze maximum performance out of this, but make something very cheap and reasonably portable for light gaming. People on mining forums report getting RX 580s under 100W, so I'm thinking this is doable - running Prime95, the CPU never reports package power above 71W, despite its 95W TDP.
So, to the point of this thread: I need a 6-pin PCIe power source for the GPU. The PSU, reasonably, doesn't have one. It has three accessible 12V leads: two 18AWG for the 4-pin EPS, and one 20AWG for the SATA connectors. The 24-pin connector is there too, but too short to be tapped into. My thought is to cut these three wires (along with matching ground wires), terminate them with a 6-pin mini-fit connector, and do the same on the other side, crimping an extra wire for PCIe power into each pin alongside the EPS/SATA power cables. Given that they're all coming from the same 12V rail, I don't see how this would be a problem.
From looking at wire gauge calculators, this should be okay. The three wires combined have an effective gauge of around 14AWG (three 20AWG =~15AWG, three 18AWG =~13AWG), which should be perfectly capable of handling far more than the PSU's maximum 17A over 20cm or so before the first terminal (again, according to a calculator, 14AWG can handle 17A over 5.6' with below 2% loss, and more than 2' with <1% loss). The EPS wire will be left alone, while I'll be running a custom cable from the SATA power cable to power the PCIe riser and a USB 3.0 AIC.
I made a very rough wiring diagram (EEs: please don't hate on my lack of diagram skills!)
Am I going to burn my house down?
