With a case so small why would you need front audio ports?
Well if you are like me it is because you have speakers plugged into the back and still use a gaming headset with 3.5mm jacks.
Lol, I had to same problem.Well if you are like me it is because you have speakers plugged into the back and still use a gaming headset with 3.5mm jacks.
What is this slot thing I keep reading about? Apparently others have the same issue with stripping.
Trace the panel onto a pair of pre-patterned sheet metal from home Depot. Done.
Hello Sir,
Thanks for your like for our case. We are also considering to release
more options for the side panels at a later date.
It is still under-evaluating..
However, due to the limited resources at our company, we'll focus on
A50 case and A50X (upgrade kit) at this moment.
Best Regards,
GEEEK
Hello.
Is there a power switch with a short depth corresponding to GEEEK A50? or L-Type.
I would like to put the Asetek 545LC on the A50 but the switch interferes.
Well you could move the switch to another location ( drill a 16 mm hole at the new location) and place a label over the existing hole. Or you could build a new panel which was my solution.
I installed a modded switch that has a blue LED for power and a white LED for drive activity. I added the front audio receptacles (HDaudio) and a reset switch (the small hole near the bottom).
neil
neil, this is great! Can you please post more detailed pics and info of the front panel audio ports? What ports did you use/buy? Maybe some info as to how you built the new front panel?
The lack of front panel audio is the only thing stopping me from getting this case.
What CPU cooler is this in the 2nd PIC? I was wanting to use a Phanteks TC12LS, but I'm not sure it'll fit. I'll get some components in tomorrow and can start trying to build my case out.A couple shots from taobao.
I have no idea lol, probably something only found in china. Maybe someone else may be able to help.What CPU cooler is this in the 2nd PIC? I was wanting to use a Phanteks TC12LS, but I'm not sure it'll fit. I'll get some components in tomorrow and can start trying to build my case out.
I had to take it all apart. That frosted window look is just the film and it was on pretty hard so I thought it was just frosted. Now I'm having some trouble with the power cables rubbing the bottom fan so I need to figure my routing out. This case looks sick, but cable routing is a total nightmare.That Black on black looks amazing. I like it better than the white/Black.
