G-unique DiY stuffs \\for ROG C8i/M8i-SVX special version directplug DCATX \
guryhwa
G-Unique
Dec 23, 2016
164
962
SVX=Super VX,it is designed for a high quality 12V powered directplug dcatx for Asus ROG C8i and M8i.
it accepts 12V input power source and supply MB 24pin and CPU 8pin simultaneously in a single pcb
the load switch mosfets on SVX can directly power upto 400watts high-end GPU.
it has lots of low ESR/ESL polymer tatanium capacitors in parallel to make very low ripple and clean output to MB's onboard device for PChifi purpose.
key feature:
all kemet T520 KO capacitors(higher grade T530 KM is available to customized)
Coilcraft high current XAL7050 choke for 5V/3.3V rails
Ti NexFet for 5V/3.3V rails
wide and thick copper trace with triple 2mr mosfets upto 45A current ability for CPU/GPU
directly deal with 12V power source with extremly high efficiency
ordering infomation updated in :https://smallformfactor.net/forum/t...bto-psus-are-now-available-direct-order.1983/
