a friend had an inno3D rtx2070 itx GPU card and ask me to design him a brickless case as small as possible,case size is :L 222mm W 287mm D 54mm ,volume is 3.44L
i plan the below layout with an interal special shape 500watts psu embedded behind the front bezel(Gstick)utilizing almost every inch of available space,:
MR30 as mini AC input plug ,and the rear panel integated with inno3D RTX2070 ports opening:
special archdaemon plug as main control unit for Gstick:
Gstick is an ATX12Vso psu and its efficiency as high as 93.5% under full load,the Gstick take cool air into the internal circuit from side of the case:
compare to a front bezel of S4mini skyeach,it is smaller:
the case included a special made G-flex pcie riser cable,and AC cord to MR30 cable :
