Hi
I'm new to SFF and I would welcome any advice that the community could offer on a new FormD T1 (non-reference) build...
I'm looking at the following components (combination of new and second hand) :
There's a chance that I may install Windows and do some light gaming at some point, but that's not the primary reason for building.
Having a quiet system when it is not under load is also important.
My main concern is how future proof the AMD-AM4-DDR4 option will be compared to the Intel-LGA1700-DDR5 option.
The AMD option is cUSD60 less expensive than the Intel option.
(The saving isn't greater than this, as if I take the AMD option, I need to order components from overseas, which means additional delivery / tax charges).
My question is : would it still be worthwhile taking the AMD option in 2024 ?
I'm leaning a little towards the Intel option, but I would welcome any thoughts from the community.
Thanks !
- Mobo - ROG Strix B550-I / ROG Strix B760-I
- CPU - AMD Ryzen 7 5700X / Intel i5 12400F (dependent on mobo)
- RAM - Kingston Fury 16GB DDR4 / Kingston Fury 16GB DDR5 (dependent on mobo)
- GPU - Zotac 3070 Ti AMP Holo / Zotac 3080 Trinity (independent of mobo)
- Cooler - Noctua NH-L9a-AM4 / Noctua NH-L9i-17XX (mobo dependent)
- Fans - Noctua NF-A12-X25 (2 units)
- PSU - Corsair SF750
Thanks !
