I'm thinking of expanding the idea I started with the Mini LP case and brainstorming another case. This case is based on the frame I have started with Mini LP with a few modifications, and will be bigger. It'll be a more "mainstream" case accommodating full-height cards up to ~210mm in length. I wanted to achieve a tower look with a case that is taller but still not very wide. Imagine something like Falcon Northwest Tiki, but much shorter from front to back.
I am not very good with names so I'm just calling it the "Flex ITX project" for now, referring to flexible choice of compatible PSUs including FlexATX, and for supporting ITX length cards.
Here will be some of the features of the case:
It's still in the brainstorming phase and I don't expect to begin construction any time soon. I don't even have all the computer parts necessary to begin testing it or demonstrating a full build, but this is a project I'd like to follow through eventually.
- "Machined" look assembled out of several aluminum panels
- Outer walls at least 3mm (1/8 in) thick
- Tentative dimensions: 33cm x 23cm x 10.5cm
- Maximum CPU cooler height of ~75mm
- Storage support: 3x 2.5" hard drives, or 1x 3.5" HDD may be possible
- PSU support: Flex-ATX, HDPLEX AC-DC, HDPLEX DC-ATX, PicoPSU and similar
- Expansion slots: 2x full-height
- Card support: ~210mm length, max height TBD
Here are views of the case layout I've had in mind. The case pieces are not final in any way whatsoever.
The white box behind the GPU represents the space for installing power supply components. You can organize cables here, add a AC-DC unit or even fit some power adapter bricks internally.
