Hi all. I've got a project with my brother to make a pc case and I would like to hear the opinion of you guys about the layout we've got in mind. The gpu placement kind of worries me, since it could possibly block the air coming into the case from the outside.
Note that the case itself will be using an itx motherboard and we plan on making it as small as we can (~25cm long, ~16cm depth, ~30cm height). On top of the case we planned on closing it with a plate.
Sides will be mesh, front will be glass panel.
Graphics card will be a gigabyte 1070 windforce (about 10cm depth) but I plan on getting a new one (3070 or amd's equivalent)
Cooler I was thinking about a NH-U9S from noctua.
140mm fans (2 intake, 2 exhaust located on the sides).
Only the cpu has been overclocked, the rest is on default settings.
Now, here is what has been on my head:
1. If the gpu blocks ~10 cm of cool air coming from the outside, leaving 2 cm of space on each side of the fan for it, will it be enough to cool it? I know that the card will be exhausting the warm air from the sides, but I don't really think that it will heat the case that much.
2. As far as I am concerned, placing a fan next to a fan won't bring more air into the gpu. Should I just deshroud the gpu?
I have also considered another scenario like this:
In this scenario I figured that the gpu would be using it's own fans to cool itself, leaving some hot air around it. One intake fan and one exhaust on top of the intake to push it out. It doesn't look that good to me but I am open to criticism.
I know that I am clueless and that it would be easier to just buy one but I think this is a great opportunity to spend more time with my brother and I would like to take it .
Thank you in advance!
