Eurocase x102 8 Liter 30$ Czech MFG . Ryzen/Nvidia build
dljonsson
urbanspaceepics.com
The mass produced Eurocase x102 (available in the EU at around 25-30$) was intended for APUs with sufficient space to store 3.5 inch drives and or a CD player. It does though require mods.
This is a work in process. I'm waiting on my order of a Ryzen 9 processor before bolting this all down.
After that a choice of appropriate cooler solution , optimization of cabling, SSD placement and drilling additional ventilation holes --- will bolt this all down. For now its up and running with no heat issues so far.
I could not wait until my budget allowed buying a designer case - so DIY for now, until an A4 Dan or
SM case is within reach.
Left MB CPU Chamber <----- > Right HDD CD/DVD Chamber that needs to be modified for GPU
Additional Ventilation holes will need to be drilled to match fan positions of GPU/CPU
Reactions: dealda
