I just got my first NUC, and it has two miniDP on the back, and an eDP on the motherboard (30pin 1.0mm).
Does anyone have any real experience working with an eDP port? Can it be used as the primary display (like an embedded project)?
I want to 3D print an iMac G4 Flat Panel case at 54% scale, and it would be ideal to run the eDP to the flat screen and use the two back panel eDP as external displays.
