The Echo 5L Case:
You can order the case now in the Brazilian Crowdfunding site catarse:
https://www.catarse.me/echo5L
Echo 5L: 649,00 BRL around 121 USD
Echo 5L + Riser: 949,00 BRL around 178 USD
The Echo 5L was designed around the RTX 3070, keeping the volume as small as possible, that way it has excellent MID/HI end options while still being portable enough to fit in a backpack.
The case is made of sheet steel with 1.5mm. Powder Coated with 6 colors of your choice.
Specs:
Dimensions: 260x200x110mm
Total Volume: ~5.8 Litros
Compatibility:
Air Coolers: 50mm height
GPUs Length: 258mm e 2.5 Slots
PSU: Flex ATX
Render Galery:
Included in the box:
Echo 5L
Instruction manual
Magnetic Feets
Recommended 3070:
Zotac GeForce RTX 3070 Twin Edge
MSI RTX 3070 Ventus 2X
You can find us in most social media:
https://linktr.ee/BCGATech
How can I communicate with the team?
R- Send us an email contato@bcga.tech or reply to this post
