Darkstone's - Phanteks Evolv Shift X Build 2018 v2
Hi everyone,
My new project is %95 completed. Thats it my case. This case is unique in the World beacuse I'm using first time with that case Monsta Radiator
This project is not completed yet because my orders are shipped but not arrived. Hard tubes and Fittings for Hard Tubes.
If you don't have experience about cable management you might have hardtime. Watercooling and Case Modding are my favorite hobbies.
*** Specifications ***
v1 link : https://smallformfactor.net/forum/threads/darkstones-phanteks-evolv-shift-x-build-2018.6712/
Hi everyone,
- Anakart : Asus Strix Z370-i
- CPU : 8700K @5hghz @72C (Delid process require not yet delidded. )
- Ram : Corssair Vengaence 2x8GB DDR4 3200mhz
- PSU : Silverstone SX800-LTI Titanium SFX-L
- SSD : Samsung 960 Evo 250GB nvme
- VGA : Zotac GTX1080ti Mini 11GB
- Radiator : Alphacool Monsta 240mm (80mm thickness)
- Pump : Swictech MCP655 (D5 Speed Controlled)
- CPU Block : EK Supreme HF Nickel
- GPU Block : Barrow 1080Ti mini (GPU Block is not arrived.)
- Reservoir : XSPC D5 Tank
- Fans : Enermax D.F Storm 120mm X2 11.8h2o (Static pressure very high special radiator fans, have mode buttons)
- Fans : Phanteks 140mm x 2
- Fittings : Bitspower G1/4 1/2
- Tubing : Flex Primochill 1/2 3/4 (PetG Hard Tubes not arrived)
- Sleeve Kit : Phanteks Sleeve Kit
- Led Strip : Aliexpress W2618B 3 pin 60 led
- EK D-TOP Mod for Pump
- Barrow TOP Mod for Pump
- Little bit pictures time
