As long as Best Buy doesn't cancel on me, I've got a 3080 XC3 Ultra and a 3080 FE coming my way this weekend. I swear I'm not looking to scalp! I only purchased both of them because I was terrified of getting cancelled on, like Amazon's massive 3080 FTW3 drop that ended up in tears for many people.
Normally, I would just take whichever one I got first and make it work, but as I'm in this favorable position, I actually have the choice. Which is the preferred one?
XC3
pros: Evga warranty, makes reselling a breeze in a couple years. No concerns about accommodating the flow through cooler. No 12 pin adapter.
cons: Apparently the rear IO doesn't line up quite right? And the card can't be screwed into the slot properly? Can someone confirm this for me? If it can't be screwed in properly, it's probably an automatic disqualification for me, as I do travel somewhat frequently with my build. I'm aware that you need to use some felt pads to keep the fan from rubbing on the side panel - I'm not worried about that.
FE
pros: Decently cheaper. Super desirable model, FEs are basically always a safe bet for future resale. If I do move to a different case in the future, this one has that tiny pcb that saves room for watercooling and would be pretty nifty.
cons: the heat. I've seen posts and optimum tech's video about mitigating this through undervolting, rotating the psu, using standoffs to create a bit more separation, etc. I've seen some say it gets pretty bad, and plenty others saying it is fine in games. Just not sure. Does using the standoffs misalign the rear IO or make it impossible to screw into the slot?
Thanks for any guidance you may have!
XC3
FE
