DAN A4-SFX v4 with Internal HDPLEX 400W AC-DC possible?
AlexTSG
599
590
www.youtube.com
I'm still working out the final configuration for an A4 v4 build, but currently it's looking like I won't need more than 400W to power it. This means that using the HDPLEX 400W DC-ATX and 400W AC-DC combo is an option.
I see that the A4 v4 has mounting points for the HDPLEX, but I've only seen photos with the DC-ATX part mounted on the graphics card side of the case. No sign of where you could mount the AC-DC brick. Are there mounting points for both, as I'd prefer not to have an external power supply, and using an SFX power supply takes away the option of using a 120mm AiO for the CPU.
If I can't then it's likely I'll go the route of using a Corsair SF600 with the Asetek 645LT, but that looks like a tight fit, and I'd prefer to go with an all copper 120mm AiO like the Alphacool.
