Printer a fan shroud to use, am going to cut down the screws and install it. Saw some discussion here: https://smallformfactor.net/forum/threads/dan-a4-sfx.12462/
And some research says it should get me a couple of degrees. Will likely swap out 24 pin ATX cable for better airflow, and turn off PBO - though 95C for this CPU seems not unreasonable (Cinebench hits this in the last 3-4 mins of its run)?
https://noctua.at/en/why-is-my-ryzen-3000-processor-getting-so-hot-why-are-ryzen-3000-cpus-running-hotter-than-previous-generation-ryzen-cpus-with-the-same-tdp-rating-is-there-anything-wrong-with-my-cooler
Am I missing anything obvious?
