Specs and setup:
It took 4 attemps to get this thing working; Changelog of failed attemps in spoiler so no one gets confused:
Final Setup:
All temps were taken after 10 mins of stress testing, Ambient @ 23°C, but they will not increase anymore (645LT has a small amount of liquid and reaches its final temp very quickly)
Stress Test: simultaneous 10 minute Cinebench R20 loop; 10 minute MSI kombustor @0% Powertune
Please forgive my low quality Pictures, i will update these once I take it apart - the build process took me 20 hours with all revsisions and i was in a bad mood... (now waiting for my Ncase M1, Dan A4 will move to my HTPC build)
Some final A4 SFX recommendations:
My verdict: The case is nice and it's impressive that you can get this hardware running properly; but it takes alot of work and attention to do so.
Personally i'm going to switch to Ncase M1 V6.1 as it has a lot of advantages for high performance systems and still fits into my backpack.
- Dan A4 SFX V4.0/3.0 hybrid
- 4.0 base frame; side panels / 3.0 front panel, USB Port /4.0 Riser
- Asetek 645LT with Noctua A9x14 HS
- high RPM L9i Version
- Arctic MX4
- Corsair AM4 mounting bracket
- Ryzen 3900X
- PBO disabled, stock TDP
- Powercolor RX5700XT Red Dragon
- 0.5mm washer mod
- modded to 2x Noctua A12x15 as exhaust
- Arctic MX-4
- Asus B450-i Strix Gaming
- Corsair SF600 Platinum
- 32gb Crucial Ballistix LT 3200mhz
- PNY Xlr8 2TB SSD
- RX5700 reference with blower, Noctua L9i with AM4 mounting and shroud; bottom Fans as exhaust; no mods; SSD underneath MB
- CPU and GPU throttled heavily
- SSD idling @ 70° under gpu load
- System is not usable due to occasional slowdowns, bad performance
- changed to Powercolor 5700XT Red Dragon; Asetek 645 LT standard A9 Fan as Pull; Case fan as exhaust
- Case fan is VERY loud (too close to Motherboard)
- MB VRM temp @ 85+°C
- GPU tjunction @ 105°
- CPU still throttling (not as badly ~3500mhz)
- you can burn your fingers when touching the case (CPU takes 60W extra with 645LT; GPU not throttling and without exhaust from blower) while stressing both CPU and GPU
- Case Fan changed to intake; modded GPU to A12x15 as intake; 0.25mm GPU washer mod; SSD moved to front
- GPU temps slightly improved
- MB VRM @75°c
- SSD idle @ 40°C
- rest showed no improvement
Final Setup:
- Asetek 645LT changed to A9x14 HS fan (intake)
- no more throttling
- Modded GPU further (0.5mm washers)
- reduced GPU-TJunction delta to 10-15°C under load, 0° @ idle
- GPU Fans changed to pull (exhaust); Controlled by GPU (Adapter)
- this heavily improved both Case temperature; GPU Temperature
- slightly more noise, from gpu, but still less than 645LT
- no more burnt fingers, case hotspot moved to PSU exhaust (!)
- removed bottom Fan grills, added 92mm wire fan grill
- further improvement on CPU and MB temps; reduces noise from Case Fan by 75%
- This setup is very quiet @ idle, but fans will spin to 100% (as loud as your average Notebook) under load
- DON'T use a 3900X (or 3950x) in this case (or any 105W CPU) if you don't have an AC unit - it will work at 20-26°C ambients but will throttle above that
- changing cTDP hurts performance by ALOT (65W = slower than 3700X except for highly threaded workloads)
- it is possible to run it without throttling, but requires some extra attention
- get the SF600 Gold if you plan on using 645LT with stock PSU cables.
- It has thinner unsleeved cables which stay together as a ribbon and can be seperated when reuiqred.
- sleeved stock platinum cables may block the GPU form seating properly and are a PITA to route
- its fan starts earlier which helps case temps
- Don't buy a board with a backside M.2 slot if you plan on using a mid-high end GPU
- the MB tray heats up and will toast your SSD
- 645LT:
- get the SF600 Gold PSU with it - it has thinner cables
- buy A9 Cromax or use a Fan coming from an L9 - they have higher RPM than normal A9 (~2500 vs 2000)
- stick to 65W CPUs if you dont plan to mod your GPU Fans (heat will build up in your case)
- the mounting screws are prone to breaking, be gentle!
- you might have to reseat it several times for optimal performance - burn in for an hour after every reseat before evaluating; my final mount was the worst after 5 mins, but the best after 1 hour
- GPU: change your fans to noctuas and run them as exhaust - it reduces Case temps considerably and helps the 645LT
