Hi all,
Just completed my first build in the A4 and super happy. Temps on the CPU are great, the GPU seems OK as well although I suspect it's chucking a bit of hot air into the case. After playing a game for a bit - 20 mins or so, the case gets pretty hot especially around the PSU on top of the case and either side in the corner. I don't think it's the PSU (it's a SW750) and believe it's the GPU chucking some hot air in the case.
My question is, should I add an exhaust case fan underneath the PSU? Is there a better spot for it? Am I missing something else?
Part list:
Part list:
