Resource icon
Enclosure Custom front and top panels for FormD T1 v2 2022-10-02
stanleyguan
114
331
stanleyguan submitted a new resource:
Custom front and top panels for FormD T1 - Ventilated front panel, and top panel with slots for greater ventilation than holes
Front panel
The ventilated front panel is 15mm thicker than the original front panel to allow for two thin 92mm fans. The mounting of the fans is achieved by adding some squishy materials (e.g. 1-2mm thick thermal pad / thermal adhesive) between the two fans and then squeezing the fans into place. It should hold the fans quite firmly in the designated cutout without the need of screws...
aesubs
mind if I ask what the water-cooling components are for this build? specifically your pump and cpu block?
