Hi everyone,
Just passing by to present my work on a overcharged The First (Ryzen 2700x + RTX 2080) from Monster Labo.
Because I'm going too far in watts consumption and thus heat, I killed 3 Noctua NF-A14 PWM that were mounted on the top due to overheating.
So I took my miter saw, a bunch of spruce wood laying around, and an angle finder to build something to address that.
After maybe too many hours, finally, I got a working custom bottom 200mm fan mount for The First:
Also, those feet won't ruin my desk varnish!
Look at the temperatures now !!! Especially the one for the SSDs:
I also cut the top and bottom panels of the PSU to allow better airflow.
The GPU can keep it's boost clock longer, this is probably why I didn't lose any degree their.
I'm very happy with the design. I choose a 60° angle for the external face of the feet. I'm planning to remake the wood parts in oak... someday.
What do you think of the look?
The feet were especially fun to make :
If anyone is interested in the SketchUp file, I'll be happy to share, but I don't know in which format to export (3DS, Collada, DWG, DXF, FBX, KMZ, OBJ, VRML, XSI there is too many).
I would like to take the opportunity to thanks Monster Labo for their great first PC case. This is by far the most silent PC I ever had.
Honiix
Furmark + CPU-Z stress test 60 minutes | Top fan | Bottom fan |
Ambient | 25°C | 25°C |
CPU | 84°C | 79°C |
GPU | 77°C | 77°C |
Chipset | 67°C | 56°C |
CPU FAN 140mm | 1032 RPM | 1041 RPM |
Chassis Fan 200mm | 643 RPM (dead bearings, makes a lot of noise) | 812 RPM (brand new) |
SSD SATA 1 | 46°C | 30°C |
SSD SATA 2 | 54°C | 36°C |
SSD M.2 | 60°C | 44°C |
Honiix
