Advice Cooling Quadro t600 with Prodesk 600 G3
dzenis94
Kyiv, Ukraine
Hello everyone! I've recently discovered the world of SFF PCs and, of course, lp sinlge slot gpus.
I got Quadro T600 to fit in the ProDesk600G3 - the PCie x16 slot is located next to the PSU, so it's only single slot gpu for me.
As you may gathered the cooling situation is horrible... The GPU gets to 70 celcius easily when I run something as old as C&C Generals. I tried to remove the plastic case, to let the heat out of the heatsink - and it helped a bit, but it's surely not the perfect solution.
I've been looking for some custom cooling system which would have a turbine fan, instead of the regular one the t600 has. Or maybe even some small water-cooling system.
Anyway, I would really love to get any help.
Reactions: zioNNN
hrh_ginsterbusch
1,111
465
Germany
wp-devil.com
maybe ask the folks over at n3rdware - they already offer aftermarket heatsink replacements for turning eg. the a2000 into a single slot GPU, so they could also adapt something for you. or at least give you pointers towards improving your situation 😎
