Concept CLAUSTROPHOBIA Line(hey Sliger...)
CLAUSTROPHOBIA
Hey folks, i've been trying to put this for the pre built companies, take a look at this.
CLAUSTROPHOBIA M
40cm/33cm/120cm
CLAUSTROPHOBIA S28
34cm/33cm/9cm
CLAUSTROPHOBIA S48
33cm/30cm/9cm
Koolance NZL-LXG2 Fittings.
140mm fans only (other than the S48).
The M version i think i could be sold as a case(Hey Sliger...).
The main advantage of The S versions is a CPU GPU face-to-face layout, so you can put taller memories, but it can ony be water cooled.
Done with free SketchUp components because i am really broke right now.
That's it!!
KSliger
Sliger Designs
May 8, 2015
855
3,186
Third one is interesting, but would have to see how temperatures on such a setup would work out to.
Only change is I would probably make the MB / GPU / PSU into the standard sandwich layout.
Luke NK
126
116
Do you mean something like this?
Lakimakromedia
27
23
That MB GPU is facing each other with PCB not with radiators. I have similar idea, but this way is dedicated to reduce space for fittings. [but if connection bridge will be changed its posible :) ]
