Motherboard Chipset PCIe lanes controlled by on a thin mini-ITX board : performance hit ?
aquelito
Piccolo PC
Feb 16, 2016
952
1,124
Hi there,
I found a custom version with a full PCIe 16X slot of this DFI SD101-Q170 thin mini-ITX board :
According to the motherboard doc, the PCIe lanes are controlled by the chipset :
Is this going to be a huge performance hit ?
Is there a risk that the physical 16X PCIe slot on the custom version of this board may be wired as 4X ?
Thanks !
Reactions: AMv8-1day
AMv8-1day
228
193
I would assume that it is PCIe x16 in formfactor alone. Allowing for greater card compatibility while still dumbing everything down to x4.
Some of the newer thin-H310/Q370 boards seem to come with x16 physical slots as well, although I haven't found clear wording yet on whether or not they're electrically limited to x4. Here's hoping though!
Check out ASRock's IMD-1212 & 1213 boards.
Reactions: ColorZepppelin
aquelito
Piccolo PC
Feb 16, 2016
952
1,124
Thanks !
I've just asked Asrock and DFI directly to confirm whether it's "true" x16 or not.
On the particular board I showed, the PCIe slot is "managed" by the chipset, not by the CPU.
Any performance drop to be expected ?
